A/C does not blow cold air?
2010 HONDA ODYSSEY
230,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARKRYD
I'm looking to diagnose the exact A/C issue (at least as much as possible or hear what to do next) with my vehicle listed above EX model (front and back A/C). I've reported my hopefully thoroughly adequate testing.
May 22, 2023 at 3:23 PM
The first thing we need to do is see if the system has enough refrigerant, here is a guide to help with that:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
This guide can help as well:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Does the compressor kick on when the A/C is at the coldest settings? Can you see the clutch engage?
May 23, 2023 at 9:58 AM
MARKRYD
Yes, the clutch definitely engages (visually confirmed). Also, I don't hear any bad sounds from the compressor. Thanks.
May 23, 2023 at 10:08 AM
I would check the out pipe from the firewall with the system on and if it is cold, I would replace the temperature actuator under the dash here is the location. Check out the images (below). Please let us know what you find.
May 25, 2023 at 9:34 AM
