A/C not blowing cold passenger side
2006 JEEP GRAND CHEROKEE
99,700 MILES • 3.7L • V6 • 2WD • AUTOMATIC
PAUL BARRETT
Just had my A/C vacuumed and recharged. Driver side is blowing cold, but passenger is not blowing cold. Could it possibly be blender doors? It should not loose Freon this fast and no notice of a leak I would think. Am I wrong?
May 11, 2017 at 1:54 PM
Yes the blend door actuator has gone bad which is located under the dash here is a diagram (BELOW) and a guide to help you get the problem fixed.
May 13, 2017 at 5:54 PM
PAUL BARRETT
Well turns out I had a bad valve stem on low pressure side and is now holding freon and staying cold longer than it did before. I may have another small leak else where. Can freon leak from high pressure side? Sure it can but thought I'd ask anyway.
May 13, 2017 at 6:02 PM
Yes it can leak from anywhere in the system, here is a guide so you can do some checking if the systems goes low again.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Please let us know what you find ;)
May 16, 2017 at 11:16 AM
