The plug to and in the ABS module is fried?
1998 CADILLAC ELDORADO
178,000 MILES • 4.8L • V8 • AUTOMATIC
CADDIEHATER
Is it possible to start the vehicle and drive it back 2.1miles to the dealership where it was purchased? I'd like to return it. Can I bypass it long enough to get there? It's a lemon and apparently has been on fire at some point and someone cosmetically fixed it to run just long enough to sale it. unfortunately, I already replaced the starter and water pump before discovering the burnt wiring harnesses. Thank you for your help.
May 15, 2024 at 10:35 PM
Sure, you can still drive the car, but the ABS system will not work so keep that in mind. Does the car not run or? The ABS system is a safety device so if you don't want to drive it without it you should have it towed.
May 16, 2024 at 12:28 PM
