ABS SENSOR ISSUE?
2015 DODGE CHARGER
145,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
BHAMDOC1
  • 102 POSTS
had these codes, then deleted them and still have the front 2 sensors without even driving the car. jacked up the car and i see front pads have been replaced but the abs sensors look old. is this something common on these cars? what are the odds that both are bad or were installed non oem or whatever the code means. i also see some loseness in the suspension maybe a control arm is bad
Mar 25, 2026 at 9:04 AM
It looks like you have codes C212A, C0031 and code C0034.
C0031 - left front wheel speed sensor
C0034 - right front wheel speed sensor
C212A - implausible/missing wheel speed signal related to ABS/ESC seeing bad data
Yep, I would check the wiring and if it looks good replace the ABS control module. There is a chance both wheel speed sensors are bad, but it is slight. Let me know what you find.
Mar 27, 2026 at 8:40 AM
BHAMDOC1
  • 102 POSTS
ya turned out that both sensors were bad. all good. thanks
Mar 29, 2026 at 7:27 AM
Wow, you don't see that to often, nice work. Thanks for letting us know, we are here to help. Ken
Mar 29, 2026 at 10:07 AM
