1998 Acura CL Radiator fan keeps running when car is turned
1998 ACURA CL
96,000 MILES • 6 CYL • FWD • AUTOMATIC
KAHNMAN
Hi, fan keeps running for like 10-20 minutes after the car is turned off. Have 2 fans and only 1 runs, the 1 on the driver side.
thanks, any help will be welcomed
Sorry I am at the library and don't have a job, when I get 1 I will donate
Jun 8, 2010 at 5:30 PM
Check the fan relay sounds like ist sticking doing that
Jun 8, 2010 at 5:35 PM
JIM SHIRRON
  • 77 POSTS
You have 2 fans, one to keep engiine cool, one to boost cooling for A/C. Find underhood fuse/relay box. With key off and fan still running, tap tops of relays with screwdriver handle and see if fan quits. If it does, you know you have a sticking/bad relay.
Jun 18, 2010 at 6:50 AM
