seat belt on the driver's side will not engage anymore, why?
1992 ACURA INTEGRA
164,000 MILES • 4 CYL • 2WD • MANUAL
DONNA ROTH
The seat belt on the driver's side of my car won't engage anymore. I checked the fuses and both are good. If I manually pull it back it will stay there, but once I open the door it won't work again. How Come?
Jun 18, 2008 at 4:33 PM
KHLOW2008
  • 41,814 POSTS
Hi DONNA ROTH, Are the seat belt lights and beeper on? You can test the motor by applying battery voltage to the # 1 & 2 terminals after disconnecting the socket.
https://www.2carpros.com/forum/automotive_pictures/192750_Acura92IntegraSeatBeltMotor_1.jpg
Aug 3, 2008 at 6:48 AM
2NDGENTEGGY92BABY408
The passenger seat belt won't retract when the door opens or closes. Seatbelt light is on and it also started beeping. Didn't have this problem before. Driver side works just fine, how do i fix passenger?
Sep 29, 2023 at 3:24 PM
So, there is an automatic seat belt motor controller that could have gone bad but let's check the fuses first. here is a guide to help and the seat belt wiring diagrams to see how the system works and which fuses to check:
Sep 29, 2023 at 3:42 PM
