I have the problem with the check engine light come on 3 times. First time was about 12/??/07 then 5/23/08 again on 7/18/08 then today 9/17/08. Every time it came on i had to disconnect the battery, then check engine light went off.
Now if i took my car to get inspection will the code P0420 show up to inspector? or it will show up as nothing, so i can the pass inspection.
It seem that light came on every two month??? why??? Could it be my catalytic converter bad or o2 sensor go bad? Why it have to be every two month it show up or just coincident.
And yes last 2 times was same code P0420.
Sep 17, 2008 at 11:47 PM
