[quote:25cddb4f35="2CarPro Jack"]Start by testing for power at the blower motor to see if it is getting any.Ifiti has power adn doesnt blow, check continuity of other wire or housing to ground, if good the blower motor is bad, if no power, check fuse 21 in underhood power center.If ok, try swapping the blower motor relay with another to see if that works, if that doesnt work,itis probably th eblower motor power transitor, located on the bottom of blower unit, see if it has power in but not out[/quote:25cddb4f35]
The blower motor unit works. I checked by connecting power to it directly. It blows pretty good :).
Next I checked if it gets any power. When I disconnect the power plug from the blower motor unit the multimeter shows 12.5VDC, whether ac is on or off. When I connect the plug back to the blower unit the meter shows 0 to very small Volts, whether AC is on or off. The fuses are all fine. I was not able to trace where the wire goes exactly. Can anybody tell me where those wires go or what should be the next checkpoint? I think that the blower motor power transitor is located outside the blower unit, do you know where it is on acura tsx?
thanks
Aug 21, 2008 at 9:34 AM
