Recently I had single digit temperatures, a few weeks after temperatures got hot enough to need cold A/C again. I noticed the air was not blowing cold, and the heat works fine. Zero issues before the freeze, A/C would blow ice cold. Can't tell if the compressor is turning on/off. Can cold weather affect the performance of my A/C and/or cause other issues, such as leaks and can using the heat/defrost create issues for the cooling components after more than normal use?
Feb 4, 2024 at 12:18 PM
