Air leak noise on cold start?
2018 TOYOTA LANDCRUISER
100,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
2018LC200
When I first start my car in the morning, I hear a hissing noise for 10-20 seconds then a pressure release sound (please see video). In addition to this the acceleration power is reduced, shifting is not smooth, idle RPMs appear high compared to before, and I occasionally have engine shake when idling.
I have had the throttle body cleaned and programed based on mechanics recommendation which seemed to provide some temporary improvement however the problem returned the following day.
Feb 24, 2025 at 2:18 AM
Thanks for the video, this sounds like an air injection problem like the air switching valve is getting stuck, can you get a better idea of where the noise is coming from? I would remove the air switching valve and clean it to see if that helps, plus with the engine cover off you may be able to get a better idea of what is making the noise. We should run the codes as well, there might be something stored there.
Feb 24, 2025 at 2:14 PM
