Airbag light
2008 CHEVROLET COBALT
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
BOSTONBOATSWAIN
  • 45 POSTS
Getting a message saying 'Service Air Bag' and light for passenger side showing seat and airbag come on. This only happens intermittently.
Any ideas? Possible it's something I can fix myself?
Thanks in advance for any suggestions/help.
D.p
Dec 2, 2019 at 9:06 AM
Good afternoon,
There is a fault code stored for this issue. I need the code so I can help narrow it down to an area of failure.
You can go to a parts store and they will read the code for free.
Dec 2, 2019 at 11:28 AM
Here is how you can get the codes please follow this video. You can get a code reader for about $35.00 on amazon. Nine times out of ten it will be the clock spring behind the steering wheel but the code with tell us more.
https://youtu.be/Pb6nXV-iamI
Dec 2, 2019 at 12:40 PM
BOSTONBOATSWAIN
  • 45 POSTS
I did code read at home, then had AutoZone and Advance Auto also do it. All 3 results are the same. No code
Is there a fuse or sensor that could never at fault or would it still be the Clock Spring?
Thanks,
D.
Dec 4, 2019 at 4:17 AM
BOSTONBOATSWAIN
  • 45 POSTS
This is what shows on my dash.
*ignore the little yellow U with the ! in the middle. It just means I paid $4.00 four a tire gauge vs paying $300.00. for sensors to be put in the tires.
Dec 4, 2019 at 4:21 AM
Can you upload a picture of what you see?
Dec 4, 2019 at 5:34 AM
Okay if you have no codes, and I hope their scanner can read ABS codes, then you need to verify powers to the module. If you have all 3 powers to the module, then you need a module.
I attached a picture and a diagram for you to view.
Dec 4, 2019 at 5:42 AM
BOSTONBOATSWAIN
  • 45 POSTS
Here's a pic of what's showing on my dash.
Dec 4, 2019 at 10:22 AM
BOSTONBOATSWAIN
  • 45 POSTS
Just called Advance and AutoZone - their scanners do not test ABS/airbag faults. As home reader said same, going to assume it doesn't either.
Dec 4, 2019 at 10:43 AM
You will need a shop with a full scan tool that can read the codes for you.
Dec 4, 2019 at 10:47 AM
BOSTONBOATSWAIN
  • 45 POSTS
Do you know anything about
INNOVA 6100P
SRS ABS OBD2 Reader?
I can get at a pretty good price
Dec 4, 2019 at 2:01 PM
No, but according to what you just posted, it will read the codes.
SRS is the airbag system.
Dec 4, 2019 at 2:03 PM
BOSTONBOATSWAIN
  • 45 POSTS
Scanner finally arrived.
On SRS it says:
B0083-71 (1-1)
Left front impact SENSOR - invalidate data
Dec 16, 2019 at 4:36 AM
BOSTONBOATSWAIN
  • 45 POSTS
*INVALIDE* not invalidate
Dec 16, 2019 at 4:37 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is what you will need to do to test diagnose that particular code: This code is relevant to the SRS-SDM (supplemental restraint system-- sensing and diagnostic module) It sounds like you are having an issue with non-communication between the sensor to the module. I've attached step-by-step troubleshooting pictures to diagnose below. Hope this helps and let us know what you find.Thanks again for using 2CarPros.
Dec 16, 2019 at 5:17 AM
Just to add to Danny's post, the most common issue is the sensor itself. I attached the location and procedure for you.
Dec 16, 2019 at 6:07 AM
