Airbag light?
2008 CHEVROLET COBALT
207,000 MILES
JOSH5755
  • 6 POSTS
The last person that owned the car changed the doors and the dash says service airbags plugged in code reader and it says that both side impact sensors are sending the wrong data so I’m trying to figure out how to program it.
Nov 25, 2022 at 5:24 PM
SATURNTECH9
  • 30,869 POSTS
What are the exact code numbers is setting in the air bag computer? Are you talking about the sensors in the front door?
Nov 25, 2022 at 8:27 PM
JOSH5755
  • 6 POSTS
Yes, the sensors in the doors don’t match the system programmed to a different VIN.
Nov 26, 2022 at 5:33 AM
Here is how to get the airbag codes SATURNTECH9 needed to help fix the problem:
https://youtu.be/gnSGfEqrf_w
Here is a scanner for about $45.00 that will work:
https://amzn.to/3sX8MCX
We need the codes to be able to fix it.
Nov 29, 2022 at 9:33 AM
JOSH5755
  • 6 POSTS
B0085_71 and b0086_71 I posted a pic of the codes, but I don’t see it on here. so here they are.
Nov 29, 2022 at 11:49 AM
SATURNTECH9
  • 30,869 POSTS
I posted the trouble tree for you but have you actually taken the inside door panel off and made sure those sensors are plugged in and wires/connectors are good to them? Thoses codes aren't for a programming error it's just saying the computer isn't seeing what it's supposed to see with the sensors plugged in.
Nov 29, 2022 at 1:12 PM
JOSH5755
  • 6 POSTS
I assumed that because the doors are off a different car that it’s sending the wrong VIN number information.
Nov 29, 2022 at 1:18 PM
SATURNTECH9
  • 30,869 POSTS
Here are the instructions for inner door panel removal.
Nov 29, 2022 at 1:24 PM
SATURNTECH9
  • 30,869 POSTS
The sensors aren't like that the computer just expects to see a set value feedback from the sensor.I would say most likely the sensor isn't plugged in the wires are damaged or maybe it's the wrong sensor and or not plugged in.
Dec 24, 2022 at 9:57 AM
JOSH5755
  • 6 POSTS
Solved it took doors apart the doors are off a 2006 and the car is a2008 the sensors are different got cheap China sensors for the year of the car had to cut off part of the plug because the 2008 sensor doesn’t fit the 2006 plug but a razor knife took off the part that is different so the right sensor would plug in and the air bag warnings shut them self-off.
Dec 24, 2022 at 10:19 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Dec 26, 2022 at 10:52 AM
SATURNTECH9
  • 30,869 POSTS
Yes, glad to hear you got it figured it out had a feeling that was one of the scenarios I was mentioning. Thank you for using 2carpros and please tell all your friends about us.
Dec 26, 2022 at 5:08 PM
