Where is the Ambient Temperature Sensor located?
2019 NISSAN KICKS
95,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
CRAIG M
  • 13 POSTS
My stepdaughter had a small collision with a small animal that affected her air conditioner. The body shop fixed the front-end damage, but the A/C only works part time. I noticed the ambient air temperature sensor was reading 20 to 30 degrees cooler than the actual temperature. I looked underneath the car and saw the temperature sensor hanging in over the bumper guard. The sensor was attached to a broken piece of plastic. I’m trying to find out where the sensor was originally attached.
Jul 4, 2025 at 9:16 PM
STEVE W.
  • 15,113 POSTS
It should go into a pair of holes in the support behind the bumper up near the A/C core. The image doesn't show it really well but the tabs squeeze in and you can remove it from the broken plastic. Then put it into the correct spot. Ideally it is there so it is in "dead" air so it can get a true reading. If it hangs loose out in the air going under the car it will read incorrect.
Jul 5, 2025 at 8:04 AM
CRAIG M
  • 13 POSTS
Thank you very much. I’ll have to look to see if the attachment piece was replaced.
Jul 5, 2025 at 8:24 AM
STEVE W. is one of our best! Please let us know what you find ;)
Jul 7, 2025 at 10:00 AM
CRAIG M
  • 13 POSTS
I found out the price it was attached was broken and not replaced. I replaced the part and was able to get the ambient air sensor replaced. However, that was not the real issue. The ac will sometime work for anywhere between 10 minutes to 2 hrs and then the fan quits blowing.
Jul 24, 2025 at 11:34 AM
STEVE W.
  • 15,113 POSTS
OK could you ask that as a different question IE AC works for a while then stops, we try to keep individual issues apart so that someone searching later doesn't get lead astray. You can use the same info to log in. Thank you
Jul 24, 2025 at 1:39 PM
CRAIG M
  • 13 POSTS
The evaporator is freezing up. Trash got past the cabin filter and it’s causing it to freeze.
Aug 7, 2025 at 12:59 PM
STEVE W.
  • 15,113 POSTS
Other than taking the HVAC case apart to get to the core you might try using a vacuum in through the cabin filter or through the blower motor opening. The blower is easy to access, remove the glove box, reach in and release the tab on the blower motor, turn it counter clockwise and it will release and you can remove it. Should give some access to go in and clean out the case.
Aug 7, 2025 at 2:44 PM
CRAIG M
  • 13 POSTS
Does the Nissan kicks have a replaceable evaporator temp sensor?
Sep 4, 2025 at 6:53 AM
STEVE W.
  • 15,113 POSTS
It has one but it is serviced by replacing the complete HVAC assembly as it is part of the case interior. I would use a scan tool to test the sensors first before going that far.
Sep 4, 2025 at 9:21 PM
CRAIG M
  • 13 POSTS
How do you test the evaporator temp sensor?
Sep 5, 2025 at 6:47 AM
STEVE W.
  • 15,113 POSTS
You need a scan tool and then using it to monitor the sensors reading you cycle the system from cold to hot.
Sep 5, 2025 at 9:40 AM
