I have an issue which is more annoying than a problem. While just trying to maintain speed at range of forty to sixty mph, the rpm is constantly going up and down 200 rpm's as if pulsating consistently, not erratically. It appears only to happen in fifth gear which makes me suspect the lock up converter is issue. In sport mode I put in fourth at same speeds and no issue, only in fifth. No codes of any kind, just changed transmission filter and fluid and no signs of burned fluid or any evident sludge in pan. Was brown, but it was changed about 90,000 miles ago, so I suspect this would be normal. Now here is another strange issue, when shifting from third to fourth under no only slight acceleration it shudders for a second, as if slipping, but never in sport mode or under regular acceleration. Do not know if problem is connected, but thought I would mention it. Runs perfect otherwise, so any suggestions?
Nov 13, 2017 at 7:58 AM
