BCM location needed
1999 CHEVROLET CAVALIER
151,834 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
WOODBOB690
  • 28 POSTS
So I have the car listed above and where the BCM should be there is a EBCM for the brakes. And for the life of me I cannot find the BCM does the 1999 have one? Please help losing my mind with this.
May 3, 2021 at 7:26 AM
STEVE W.
  • 15,116 POSTS
The EBCM should be under the dash on the left side mounted on the inside of the A pillar about inline with the fuse block. It is behind the trim panel. That car doesn't have a BCM, instead it uses individual modules for the various systems. What issue are you trying to solve?
May 3, 2021 at 9:55 AM
WOODBOB690
  • 28 POSTS
The pass lock I've tried everything and I mean everything to get by it and it just won't work. it says that it received a fuel shut off signal and it is also in relearn mode but it won't relearn.
May 3, 2021 at 10:12 AM
STEVE W.
  • 15,116 POSTS
Okay, I know it's annoying but we try to keep issues separate to make searching easier. So if you don't mind could you ask this as a pass lock question. Fill in any information you can think of and if you have a scan tool what it says. Thanks.
May 3, 2021 at 3:00 PM
