Blend door actuator locations?
2013 TOYOTA HIGHLANDER
181,573 MILES • 3.5L • V6 • 2WD • AUTOMATIC
RPEN
A/C not blowing cold on driver side of 2013 Toyota Highlander V6 3.5L. Has manual climate controls. Where is blend actuator located exactly for the driver side? Are there any diagrams?
Jun 9, 2025 at 10:49 PM
STEVE W.
  • 15,116 POSTS
There is only a single blend door actuator that controls both sides in that system. As such it likely isn't the actuator if one side can switch temperatures but the other doesn't. Instead, I would use a gauge set to see if the vehicle has a complete charge and if the compressor is operating properly. Either one could cause the core to only cool partially.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
If the charge is okay but you still don't get cold air on one side, I would use an inspection camera to see if there is something blocking airflow on the core.
Jun 10, 2025 at 10:23 AM
