Blinker problems
1992 CHRYSLER LE BARON
136,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
DARRELL JAMES
Emergency flashers and blinkers do not work. If this a common thing I need to know where to start?
Apr 16, 2017 at 6:28 AM
It sounds like you have a flasher that is out which is located int he fuse panel but we should check the fuses as well.
Here is a guide to help you check the fuses.
Here are the fuse locations and what they go to (below)
Jan 17, 2018 at 12:23 PM
