Ignition, key will not turn past stage 1
BMW 325
JSHERET
I have a 325I BMW 1989...213,000kms
It was perfect then I tried to start the key would turn to stage one that works radio, wipers, blinkers, however it is locked and will not turn further....
I am new to this car..however could it be the key?, could it be the ignition, or what about this code stuff, do I need to enter a code??
thank you
Mar 12, 2006 at 11:34 AM
You need a engine scanner to tell you your trouble codes. Then replace the shorted sensor and clear codes after the repair is complete.
Feb 16, 2006 at 11:55 AM
BAMADAVE
  • 8 POSTS
Could the wheel be torqued to the side. Try taking the pressure off the steering wheel when trying to start it.
Mar 30, 2006 at 6:45 AM
