Valvtronic Code 135C11 for the motor?
2014 BMW 320I
109,000 MILES • 4 CYL • TURBO • 4WD • AUTOMATIC
BEETLEPUNK21
  • 124 POSTS
Hello, I just bought this BMW and have quite a few codes that I pulled from the computer. One in particular that I am concerned about is this 135C11 code for the valvetronic motor.
What would be the process to correct or fix this issue?
Can it be reset? Or is there something that can be done to correct the issue without having to replace it?
Thanks in advance!
Jul 28, 2025 at 5:54 AM
So this is telling you the high pressure fuel pump cannot keep up or the fuel pressure sensor is going out.
Code 135C11 - DME: Fuel pressure too low during cold start
I would try the sensor first because they have a high failure rate, and if that doesn't help you will need a high pressure fuel pump, also check the cam lobe once the pump has been removed, there is a chance the camshaft lobe is worn out FYI. Here is how to change the sensor and HPFP. When you change the parts out be sure to loose the fuel line to release the fuel pressure slowly. Check out the images (below). Please upload pictures or videos in your response
Jul 28, 2025 at 2:40 PM
BEETLEPUNK21
  • 124 POSTS
I attached a photo of the code. So, even though it says “valvetronic servomotor position sensors signals implausible” it really means “Fuel pressure too low during cold start” ???
Aug 1, 2025 at 10:13 AM
That is a general code that is telling you one of the sensor is giving back information that is not viable. which will be the oil pump control solenoid as per the other codes.
Aug 1, 2025 at 11:47 AM
BEETLEPUNK21
  • 124 POSTS
Ahhh, gotcha. Thank you for clarifying. I dropped the oil pan and found a few broken pieces of plastic from the timing chain guides in there. The oil pump pick-up looked clean and not clogged. I’m assuming that maybe there were some plastic pieces close to the pick up and perhaps it was restricting oil flow?
Because I wouldn’t think that the oil pump is bad, right?
Aug 2, 2025 at 6:53 AM
No the oil pump is probably good, it is the oil pump control solenoid that needs to be replaced.
Aug 2, 2025 at 9:22 AM
BEETLEPUNK21
  • 124 POSTS
How can I test for that to see if it’s good or not? I have an autel mp808 scan tool
Aug 2, 2025 at 9:26 AM
Bench test by applying 12 V power to the valve terminals:
It should click or move slightly when energized. When power is removed, it should return to resting position. If it doesn’t move or sticks, it’s defective and needs replacement.
Aug 2, 2025 at 9:28 AM
BEETLEPUNK21
  • 124 POSTS
Do you have any detailed instructions for that? Both removing the solenoid and testing it
Aug 2, 2025 at 9:30 AM
It seems like you have two problems, with this car, did you ever remove the high pressure fuel pump to check the camshaft lobe?
Aug 2, 2025 at 11:03 AM
BEETLEPUNK21
  • 124 POSTS
I have not
Aug 2, 2025 at 11:04 AM
lets try that, we need to get to the bottom of:
Lets keep the oil pump problem on this thread.
https://www.2carpros.com/questions/low-oil-pressure-74812562
Aug 2, 2025 at 11:14 AM
BEETLEPUNK21
  • 124 POSTS
Hey Ken, could you please send detailed instructions on removing the high pressure fuel pump to check the camshaft lobe?
Thank you very much for helping me
Aug 2, 2025 at 1:11 PM
That is all they give us, I would crack a fuel line to relieve the pressure on both high and low side. Also you can upload images so I can see the vital parts and I can tell you if they need replacement. I would replace the HPFP because they have a high rate of failure.
Aug 3, 2025 at 11:53 AM
BEETLEPUNK21
  • 124 POSTS
I ended up selling the car so I never got down to the bottom of it, but Thank you for the help and great information! You guys rock!
Jan 20, 2026 at 7:25 AM
Thank you, yep that is one way to fix the problem :) Let us know how it goes or if you need anymore help with other cars. Ken
Jan 20, 2026 at 9:19 AM
