Bosch Injector programming to the PCM?
2009 CHEVROLET CAPTIVA
130,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
ABAYA
  • 77 POSTS
Hi, Please help me to program fuel injector in the calculator. Thank you.
Aug 18, 2024 at 1:47 PM
Sure, this involves connecting a high end scanner that will supply the injector number into the PCM which will help it understand the programming for optimization.
Select Injector Coding:
Find the "Injector Coding" or "Injector Programming" option in the scan tool’s menu. The exact wording may vary depending on the tool.
Enter the Injector Codes:
The scan tool will prompt you to enter the calibration codes for each injector. These codes are usually a series of letters and numbers printed on each injector. Carefully enter the code for each corresponding injector (cylinder 1, cylinder 2, etc.).
Let us know if you need anything else.
Aug 19, 2024 at 9:32 AM
ABAYA
  • 77 POSTS
Thank you very much, it' clear.
Aug 19, 2024 at 1:14 PM
You are welcome, please use 2CarPros anytime we are here to help.
Aug 20, 2024 at 8:58 AM
