Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Buick
Rendezvous
Exterior Light
Brake Light
Fuse
Brake light fuse
2006 BUICK RENDEZVOUS
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIM KARG
MEMBER
1 POST
FOLLOW
Where is the fuse for the brake lights located? nothing is listed on the list of fuses about brake lights.
Nov 4, 2017 at 7:08 AM
CERTIFIED EXPERT
The problem is probably with the turn signal flasher module which control everything for the brake lights.
Here is a wiring diagrams and a guide so you can do a test to confirm:
Here is the location of the flasher as well and you should check all of the fuses:
Nov 5, 2017 at 6:18 PM
