Pedal travels to the floor when braking?
2012 SEAT IBIZA
108,000 MILES
JACKTAMPS
  • 6 POSTS
Pedal travels to the floor when braking and the brakes don’t work great, bleed brakes haven’t sorted it, when the car is off, and I press the brake pedal until it’s hard it stays hard for a bit before going down again does this mean my brake booster is gone?
Oct 15, 2024 at 9:55 AM
Does the booster make a hissing sound while driving, if not it is probably okay. It sounds more like the brake master has gone bad, or you have a seized caliper slide.
Please go over these two guides and get back to me:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
And this can make the pedal go to the floor as well:
https://www.2carpros.com/articles/discover-why-automotive-brake-pads-wear-unevenly
Let us know what you find.
Oct 15, 2024 at 11:48 AM
JACKTAMPS
  • 6 POSTS
I have taken off both callipers and can push back the pistons in them
Oct 24, 2024 at 7:12 AM
Did you look at the guide? it would be the caliper slides you are checking, also if they are okay I would replace the brake master cylinder.
Oct 24, 2024 at 9:45 AM
JACKTAMPS
  • 6 POSTS
I’ve replaced the master cylinder still getting the same issue.
Nov 1, 2024 at 9:28 AM
Can I ask if the brake pedal is good if you pump it, or does it just go to the floor all the time?
Nov 1, 2024 at 11:38 AM
JACKTAMPS
  • 6 POSTS
When I’m driving it if I press it a few times the brake seems to feel better.
Nov 1, 2024 at 12:31 PM
To check if the booster is okay, with the engine off pull the vacuum line from the booter and you should hear air escape, if not the booster is bad. I would again check the caliper slides, not the piston. Can you upload images of the caliper so I can see what I am dealing with?
Nov 2, 2024 at 9:06 AM
JACKTAMPS
  • 6 POSTS
Yeah, I can hear air escape when I disconnect the pipe going to the booster and with the piston pushed back should I have a bit of movement in the Caliper to tell me the slides are okay I’ve had both the calipers off, and the slides come out fine.
Nov 5, 2024 at 8:00 AM
Thanks for the images, it looks like you have the calipers on the wrong side, the bleeder should be at the top.
Nov 5, 2024 at 10:31 AM
