When stopping there is a jerking feeling that is not coming from the pedal
1995 PONTIAC TRANSPORT
225,000 MILES
FIXITMR
  • 9,990 POSTS
so when i stop i get this jerking feeling but not in the pedal. like an out of round rotor but the pedal does not throb. i jacked it up one side at a time and ran i up to speed then applied brake with no noticeable jerking. i know that the rotors and pads had been recently replace when i got it.
Dec 26, 2016 at 6:23 PM
STEVE W.
  • 15,116 POSTS
Sounds like it was setting a while and rusted the rotors under the pads. Leaves a spot that will grab as you brake. Easy solution it to pull the front rotors and turn them. (the fronts are more likely to be felt than the rears).
Dec 27, 2016 at 12:24 AM
FIXITMR
  • 9,990 POSTS
i did pull wheel on one side to look at rotor and all looked fine. i did put a lot of miles since purchase i do not remember any big issue with braking right after purchase, but yes it had been sitting at least six months. rear drums look original. i also notice i have a wheel bearing going bad not sure if front or rear. wondering if its rear it would make brake wear/grab funny?
Dec 27, 2016 at 3:49 AM
STEVE W.
  • 15,116 POSTS
Bad bearing could do it, brake pressure would try to "straighten" the drum/disc and grab as it moves.
Dec 27, 2016 at 9:45 AM
FIXITMR
  • 9,990 POSTS
well it was a cracked rusted frame and it finally broke right where the rubber mount is! i welded it back on but i still have a clunk noise like if i go a few feet in reverse then put in drive while rolling big clunk!! so now i'm wondering where the motor mounts are located!!
Jun 3, 2017 at 8:04 PM
