CV axle and lower control arm replacement?
2009 NISSAN ROGUE
77,000 MILES • AUTOMATIC
ROSIE THE RIVITER
The left front CV axle, and both frontal control arms need replacing. how dangerous is my car to drive before I can get this fixed?
Sep 30, 2020 at 11:23 AM
What is the reason for the control arms being replaced? If they are loose and are causing the vibration then I would not drive it. However, if they are not loose and the vibration is caused by the rotors being warped then it is okay for now.
Let's start why the vehicle needs these parts and then we can go from there. Normally when the brakes pulsate when pressed it is because the rotors are warped but again we need to find out why these other parts need replaced. Thanks
Oct 1, 2020 at 3:57 PM
Here are two guides to help walk you through the repair with instructions in the diagrams below to help you with your car:
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
and
https://www.2carpros.com/articles/replace-cv-axle
Oct 2, 2020 at 9:41 AM
