Location of fuel pump fuse or relay
1995 BUICK CENTURY
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAFEMJE
My understanding is that this fuse is located behind the passenger headlight. It was dark out last night and I don't think they were marked. There were at least 3 or 4 that I could see. They all look the same. My car wont start. It cranks fine but I can't even get a single pop out of it. No firing at all. I would like to check the fuse and hoping it is an easy fix.
John Hafemeister.
Dec 4, 2008 at 6:30 AM
Hey John,
The fuel pump relay is on the front core support on the right side near the radiator. The fuse is right next to it. Here is a diagram for you CLICK BELOW.
Dec 1, 2016 at 4:11 PM
DECLARE43
Where is the fuse located for the fuel pump? The manual just says it is under the hood.
Mar 1, 2019 at 6:31 PM (Merged)
The fuel pump fuse is in a stand alone fuse holder near the wiring harness in the engine compartment right front on the relay bracket, C4
Here is a guide and some fuel pump and engine wiring diagrams along with the fuse panel diagrams (below).
