1963 Buick Skylark convertible top pump motor
1963 BUICK SKYLARK
OLD.N.BOLD
  • 11 POSTS
Electrical problem
1963 Buick Skylark
it stopped working so i checked to see if it is getting
power to the pump motor & it is.is there some kind
of breaker,fuse or fuseline after the wires go into the
motor unit?the only other thing different is that it is
colder out(below 30')& i don't know if that has any-
thing to do with it.i never had a convertible before.
thanx,Don
Dec 25, 2009 at 1:01 PM
HMAC300
  • 48,601 POSTS
if you are getting power to the motor then the motor is probably bad. You can have someone activate teh motor and you tap it with a small hammer and see if it starts to work. Otherwise you'll have to take it to a shop like a starter/generator repair and they can check it for you..
Jan 31, 2010 at 6:19 PM
OLDNBOLD
hi,yes that's exactly what i did do.it worked 4 maybe
1-3sec.when i tore it apart there was a broken wire
on 1 of brushes,i guess a seal must have gone bad
also because it was all wet inside motor.thanx,Don
Feb 1, 2010 at 8:02 AM
HMAC300
  • 48,601 POSTS
if the brush wire is broken then take it to a starter generator rebuilder he can get the motor working again. You may have a field coil or armature bad as well as bushings. I'm sure you will be able to find the seals to fix the leak as well on the pump.....
Feb 1, 2010 at 10:37 AM
