1991 Buick Skylark ecm/pcm
1991 BUICK SKYLARK
35,000 MILES • 4 CYL • FWD • AUTOMATIC
HARRY/ALICE
  • 4 POSTS
how do i check the three inputs to the unit for the correct resistance.
Feb 9, 2010 at 12:04 AM
BUDDYCRAIGG
  • 2,262 POSTS
resistance to what?
One of the sensors, or a circuit of wire...
what are you wanting to test?
Feb 9, 2010 at 12:28 AM
HARRY/ALICE
  • 4 POSTS
[quote:cf874b20c6="buddycraigg"]resistance to what?
what are you wanting to test?[/quote:cf874b20c6]
lack of resistance in 1 of 3 cables going to the ecm/pcm caused an overload. what pins do i check
in the 3 cables to correct the problem before i
replace the electronics?
Feb 9, 2010 at 11:29 PM
BUDDYCRAIGG
  • 2,262 POSTS
Are you suggesting that you have 3 bundles of wires going to your ECM. And one of those wires, in one of those bundles has low resistance. And thus causing your ECM to blow up?
Feb 10, 2010 at 12:03 AM
HARRY/ALICE
  • 4 POSTS
[quote:3c3c733a13="buddycraigg"]Are you suggesting that you have 3 bundles of wires going to your ECM. And one of those wires, in one of those bundles has low resistance. And thus causing your ECM to blow up?[/quote:3c3c733a13]
yes, the resistance to the ecm in one of the bundles
is too low or nonexistent, thus frying the system. it
should be a pair of pins in each bundle that could
give the answer so i can correct it before i order a new ecm/pcm
Feb 11, 2010 at 12:20 AM
BUDDYCRAIGG
  • 2,262 POSTS
If you know what the resistance to each wire should be. Then you should be able to check them to find the bad one.
But I'm curious, how did you come up with this low Resistance idea.
Feb 12, 2010 at 9:27 PM
HARRY/ALICE
  • 4 POSTS
[quote:d5f4ded15c="buddycraigg"]If you know what the resistance to each wire should be. Then you should be able to check them to find the bad one.
But I'm curious, how did you come up with this low Resistance idea.[/quote:d5f4ded15c]
from the buick manual (chilton). now i need to go to the library in phoenix, az thanks anyway harry h
Feb 13, 2010 at 12:42 AM
2 LINSEY
  • 287 POSTS
Thank you for your donation. We appreciate it and look forward to helping you in the future.
Mar 1, 2010 at 3:27 PM
