1994 Cadillac Seville Coolant temp
1994 CADILLAC SEVILLE
179,966 MILES • V8 • FWD • AUTOMATIC
BRADYBOY2005
I was recieving a coolant level low warning so I added some water and the temp does not seem to be going down is this a problem
May 13, 2008 at 8:08 AM
BUZZSAW
  • 1,198 POSTS
[quote:e03574b869="Bradyboy2005"]Engine Cooling problem
1994 Cadillac Seville V8 Front Wheel Drive Automatic 179966 miles
I was recieving a coolant level low warning so I added some water and the temp does not seem to be going down is this a problem[/quote:e03574b869]
yes, overheating it too much will cause headgasket problems, if its not allready there
have it pressure tested and checked for leaks, change the thermostat, ck the front fans, ck the water pump and its belt and tensioner, its on the front head drivers side, if all this is ok then you have headgasket problems
May 13, 2008 at 11:23 AM
