Camshaft position bank 2?
2009 CHEVROLET TRAVERSE
208,000 MILES • 3.6L • 6 CYL • AUTOMATIC
What can cause this issue?
Aug 5, 2025 at 9:53 AM
What code number is it?
Aug 5, 2025 at 10:50 AM
P0024
Aug 5, 2025 at 11:16 AM
Yes, the dreaded camshaft code, here is what the easy fixes are.
1. Oil change/filter with correct 5W-30 oil.
2. Cleaning or replacing the Bank 2 exhaust camshaft actuator solenoid.
If these don't work, then:
3. Timing chain/guide camshaft actuator replacement if stretched (common on 3.6L engines with 100k+ miles).
Here is the location of the bank 2 camshaft actuator so you can check it out, it may have metal/debris int eh oil port screen which you can clean and reinstall. Check out the images (below). Please upload pictures or videos in your response.
Aug 5, 2025 at 12:43 PM
