Can you put LEDs in, yes. Should you, No. Why? First there are no street legal LED conversion bulbs or kits on the market. That is because of the laws that automakers need to follow to get a car legal. They have to have each system on the car accepted by the government before it can be used on the street. Part of that is getting the headlamps systems approved. Under that approval if a car was built with halogen lighting you legally cannot swap in HID or LED. The other reason is that LEDS are a different light source type. In a Halogen there is a long filament that stretches between the posts inside the lamp. It radiates light all around it and across it. The lens and reflector in the vehicle is designed to capture and align that light so it is an even light that can be focused as needed. An LED on the other hand is a point light source. Instead of a wide filament of light it is small pinheaded spots that give off light. The problem then becomes that the reflector cannot capture and focus that light into a usable beam. You end up with a glare that bothers oncoming drivers because the light bounces around the reflector at random. The lights seem brighter from behind because they are not focused and they light up more of the area around the light. Sort of like driving in snow or fog where your headlights reflect back at you. At the same time the light, out the front isn't aligned so you don't get a working high or low beam.
Then there are also the issues with the vehicles electronics. Because many of the LEDs out there are of low quality, they cause issues with the vehicle itself. Odd codes or very unexpected operation from the way they are made causes problems.
Nov 11, 2024 at 11:02 AM
