Engine has no spark?
2007 OPEL CORSA
35,760 MILES • 1.4L • 4 CYL • 2WD • MANUAL
CHARLES MOLIMISI
The car doesn't crank with the key and there's no spark.
Feb 19, 2020 at 11:15 AM
The vehicle isn't offered in the US, but I will try to help.
If you have no spark or starter engagement, have you checked for ignition or starter fuse issues in the under hood fuse/relay box? Do all other electrical components work? Have you checked the starter for power?
You indicate you are a mechanic, so I'm not sure what to add that will help you. However, here is a link that explains how to check for power at the starter. I hope it helps.
https://www.2carpros.com/articles/starter-not-working-repair
Feb 19, 2020 at 6:44 PM
JURGENS
There is no spark at the plugs on my opel corsa 1.3 lite please could you help?
May 19, 2021 at 2:27 PM (Merged)
To me it sounds like you have a crankshaft angle sensor that needs to be replaced from what you have described. Here is a guide that will give you an idea of what you are in for when doing the job Your car will be a little different but you will get the idea.
Cheers
JURGENS
I wasn't sure what was causing the problem but I followed your suggestion and replace the cranks sensor and BAM! the car started and works great. Thanks 2Carpros I love this site.
Nice work, we are here to help, please use 2CarPros anytime.
JOHAN HALGRYN
Good day, i am sitting with a problem my Opel Kadett does not have spark just after they replaced head gasket.
Please can you give me some advise?
I'm not real familiar with the vehicle because it isn't offered in the US. However, I try my best to help.
First, the most common cause of having a no spark condition is a faulty crankshaft position sensor. Now, since there was a lot of work just done, something could have been left disconnected.
Here is a link that explains in general how a crankshaft position sensor is replaced. Take a look through it and then try to locate the one on your vehicle.
I'm not sure what year your vehicle is, but if it is newer than a 1995, it should have an OBD2 diagnostic system. If it does and you have a live data scan tool, plug the scanner in and crank the engine. If the sensor is bad, in most cases you will not have an RPM signal.
