replacing brake booster
2002 CHEVROLET TRAILBLAZER
167,000 MILES • 6 CYL • 4WD • AUTOMATIC
MS. LISA
Vehicle has no brakes after changing the brake booster, adding new lines, recap brake fluid, bled, and fairly new master cylinder. The brakes goes right to the floor and you hear air. Can someone help me?
Jul 28, 2019 at 5:06 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with the vacuum hose going to your brake booster or the brake booster check valve. In the diagrams down below I have included a factory diagnostic troubleshooting flowchart for your vehicle's brake assist system as well as instructions for the removal and installation of the vacuum brake boost check valve and hose. Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Feb 24, 2021 at 7:47 PM
MS. LISA
I will check. thank you
If I can jump in here. does this car have ABS? if so you may need to have the ABS valve opened using a scan tool while bleeding to get the air out. This guide can help as well:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
