Car A/C not working
2014 SUZUKI SWIFT
12 MILES • 1.5L • 4 CYL • 4WD • MANUAL
JOYDEEP CHATTERJEE
After recharging refrigerant my car A/C blowing cold air for 10 to 15 days, but after that not blowing cold air.
Mar 20, 2020 at 3:04 AM
STEVE W.
  • 15,113 POSTS
Why was it recharged? If it was due to it not working because it was empty, was a leak repaired or just charged? First thing would be to check and see if it is still charged using a pressure gauge set. If you attach the gauges and it reads zero then you have a leak.
Sometimes you can find a leak by looking along the lines and fittings as well as at the condenser core in the front and look for oil residue. If there is nothing seen then the next step would be to add a small charge then use a sniffer to detect the leaking area.
From there you would have a starting point.
Mar 20, 2020 at 3:36 AM
Good morning,
Did you use a recharge kit form a parts store? If you did, hook it back up and see if there is a pressure reading on the gauge. That will tell you if you have pressure for the system to turn on. When the pressure gets too low, it will not turn on.
Mar 20, 2020 at 5:49 AM
JOYDEEP CHATTERJEE
hope this is not the problem of the compressor.
Mar 20, 2020 at 12:02 PM
STEVE W.
  • 15,113 POSTS
More likely it has a leak, that is why you start with a pressure reading. There are a lot of places that can leak.
Mar 20, 2020 at 12:08 PM
This guide will help show you how to find the leak:
https://www.2carpros.com/articles/air-conditioner-leak-detection
Mar 20, 2020 at 12:30 PM
