Car hesitates and rattling under hood
2006 FORD MUSTANG
140,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CHAD LEAZER
In the past it would backfire when I hit passing gear. Recently it has been hesitating when I accelerate. It also makes a rattling noise until I let off of the gas. It threw a code saying it was a faulty cam shaft position sensor bank2. I replaced the sensor but problem persists. I am going to change plugs and coils next weekend. Any ideas? Thanks in advance.
Feb 3, 2018 at 6:44 PM
Do you still have a check engine light on? Also, if you can shoot a quick video of the engine noise and upload it here I can tell you exactly what the noise is.
Please let us know.
Feb 5, 2018 at 11:10 AM
CHAD LEAZER
I tried to make a video while driving and one sitting idle after I got home. Quality probably is not the greatest. Thanks in advance for your time.
Feb 5, 2018 at 12:47 PM
CHAD LEAZER
Yes the check engine light is still on.
Feb 5, 2018 at 12:48 PM
Thanks for the videos they really help. Because of the pulsing out of the exhaust pipe it sounds like you may have a burnt valve. From the first video right at the end I thought I heard a timing chain issue like a guide let go but will need more engine running video to be sure. (give it a quick rev)
I would first read the codes to see which cylinders are effected. Then remove the spark plugs to check their condition. Then I would roll a compression gauge into each for the cylinders and take readings.
Here are tow guides to help us find out whats going on:
and
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
Feb 6, 2018 at 10:42 AM
