The engine runs poorly with no power when it is cold?
2007 CHEVROLET TRAILBLAZER
100,000 MILES
SARAH NARVAEZ
  • 5 POSTS
My vehicle listed above, in the morning starts fast but does run bad after like 2 minutes. We do it three times and press the gas and it will run after the car is up to almost 210 temperature, then we drive it fine but by the next morning it’s doing the same thing.
Sep 22, 2022 at 6:16 AM
This happens when the engine coolant temperature sensor goes out, but we should run the codes first. here is the location of the sensor just in case you want to change it out. You can get a code scanner from Amazon for about $20.00.
Here is a guide/video to show you how:
Here is a scanner link:
https://amzn.to/3Qi1SS6
Sep 22, 2022 at 10:29 AM
SARAH NARVAEZ
  • 5 POSTS
Thanks. Okay, we have used the computer and we get p0132, p0030, p0315, and sometimes p0496.
Sep 22, 2022 at 11:59 AM
SARAH NARVAEZ
  • 5 POSTS
What tools are needed on the vehicle i have?
Sep 22, 2022 at 12:26 PM
These are oxygen sensor, crankshaft relearn sensor and EVAP sensor codes, how long has the check engine light been on and did these codes come up all at once?
Sep 23, 2022 at 11:53 AM
SARAH NARVAEZ
  • 5 POSTS
Okay, we are putting a new crankshaft sensor today and no the po496 recently popped up.
Sep 23, 2022 at 12:02 PM
Okay, once the sensor is in place clear the codes and let me know what happens.
Sep 24, 2022 at 10:07 AM
SARAH NARVAEZ
  • 5 POSTS
Okay, crankshaft sensor is on still in morning sounds like it wants to cut off once it’s warm runs good. We have to replace the condenser it had a leak, but we put stop leak for the moment.
Oct 6, 2022 at 4:32 AM
Okay, lets service the throttle bore which can cause the problem as well.
Please go over this guide and report back.
Oct 6, 2022 at 11:31 AM
