Code p1382, shuts off when i press the pedal?
1998 HONDA ACCORD
250 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
DERT BROWN
  • 8 POSTS
I just recently installed the engine into the vehicle with no issues before removing it. Now in this car I have a p1382 that will not go away and the car cranks fine but as soon as the pedal is pressed it shuts off. I have changed the fuel pump and fuel injectors, still the same result. I have also tried 4 different distributors to no avail. I'm stuck scratching my head.
Jul 30, 2025 at 8:04 AM
So this code comes up when the crankshaft position sensor needs to be replaced or the connector/wiring checked. Here is the location of the sensor:
P1382 - Cylinder Position (CYP) Sensor No Signal
Jul 30, 2025 at 10:41 AM
DERT BROWN
  • 8 POSTS
That info is incorrect but thank you for your time. The cyp for this model is made in the distributor.
Jul 30, 2025 at 10:49 AM
Hmm, I don't think I am wrong, please check the images again. I even checked 1997 model year.
Jul 30, 2025 at 4:46 PM
