stalling at idle
2011 DODGE CHARGER
147,000 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
MILOS
  • 5 POSTS
Hi, i had a key not detected message ever since i bought the car. I recently watched a video on YouTube on how to fix that. It was as simple as removing the battery in my key fob, disconnecting the positive side on my car battery and waiting for one minute then putting everything back to normal and it fixed by problem which was great. However, since i did that i now have a new issue and i'm not sure if its related to what i did or is it just coincidence.
When my car is on idle or if i stop at a red light and turn off the windshield heating, the car shuts down. I then put the car in park mode and i just start the car again and it starts no problem.
Do you have an idea on what the issue could be ? Some people tell me it's maybe the BCM ( body control module ) if i replace that and it persists, can i be something else ?
Thank you very much :)
Mar 1, 2021 at 3:40 PM
If I understand, when you turn off the W/S heater, the car stalls. Is that correct? First, I don't see how it's connected to the BCM. Do you mean when you turn the w/s heater On it happens? That could be due to an electrical draw and a weak alternator.
Also, are you referring to the defroster and not a heated windshield? If it is the defroster, see if it does the same thing if you turn the A/C on and let me know. If it does, pay attention to the engine RPM's at idle and let me know that as well.
Mar 2, 2021 at 5:01 PM
MILOS
  • 5 POSTS
Hi Joe,
Yes the windshield defroster is what i meant sorry.
When i turn it "on" and leave it let's say for couple of minutes then turn it off it stalls. I will try the A/C thing and get back at you.
Thank you for your support.
Mar 2, 2021 at 5:28 PM
Let me know about the A/C. Interestingly, the A/C compressor engages when defrosting. The PCM controls idle speed. Basically, the PCM commands the throttle closed reducing air flow into the engine and the idle speed decreases. In order to increase idle speed, the PCM commands the throttle plate open allowing more air to pass the throttle plate.
When the A/C compressor is engaged (for A/C or defrost) the added load requires the PCM to increase the idle speed to eliminate stalling. In this case, when you are turning it off, it sounds like it's going too far for reducing the idle speed. It's a theory at this point.
Listen, if you haven't, I strongly recommend having the can-bus system scanned. CAN stands for controller area network. It's nothing more than a network of computers/modules tied together via a few wires. When you scan the can, it will identify any codes stored in any of the modules.
Here is a video that shows how it's done:
https://youtu.be/InIlnsjOVFA
Let me know what happens with the A/C. Also, if the check engine light is staying on with the engine running or not, I recommend having it scanned. Hopefully, it will help guide us in the right direction.
Take care and let me know what you find.
Mar 3, 2021 at 4:37 PM
MILOS
  • 5 POSTS
Hi Joe, so i tried turning A/C on while having the defrost and it does the same thing when i turn off the windshield defrost the car shuts off. I recently changed my A/C compressor could it be related to that ? I went back to my mechanic and he told me that it was changed correctly nothing is unplugged or nothing seems wrong. Does that mean the A/C compressor is malfunctioning ? When i scanned the check engine light it said something failed with BCM the error code was: u0143-00.
Thank you for your time.
Mar 3, 2021 at 4:49 PM
It could be the BCM, but the code could mean a few things. The CAN system (controller area network) could be the issue as well. If you look below at pic 1, it shows the possible causes for this code to set.
To determine the cause requires a good bit of diagnostic work. I will add the diagnostics for your review. Let me know if this is something you are comfortable doing and if you have the tooling.
_________________________________________
1. VERIFY DTC IS ACTIVE
NOTE: Make sure the battery voltage is between 10 and 16 volts before proceeding.
1. With the scan tool, read active DTCs.
Is this DTC active?
Yes
- Go To 2
No
- See: A L L Diagnostic Trouble Codes ( DTC ) > Manufacturer Code Charts > Stored Lost Communication DTCs Perform the STORED LOST COMMUNICATION DTCS diagnostic procedure.
2. CHECK FOR ANY OF THE FOLLOWING ACTIVE DTCS
1. With the scan tool, read active DTCs from all modules.
NOTE: Check for BCM configuration, CAN Interior Bus hardware electrical, VIN Missing/Mismatch, battery or ignition related DTCs.
Does the scan tool display any active DTCs to the conditions listed above?
Yes
- Go to and perform the appropriate diagnostic procedure.
No
- Go To 3
3. VERIFY THE VSIM IS ACTIVE ON THE BUS
1. Turn the ignition on.
2. With the scan tool, verify the VSIM is active on the bus.
Is the VSIM active on the bus?
Yes
- Go To 4
No
- See: A L L Diagnostic Trouble Codes ( DTC ) > Manufacturer Code Charts > Communications - Verbose Codes and perform the NO RESPONSE FROM VSIM diagnostic procedure.
4. CHECK FOR ADDITIONAL COMMUNICATION RELATED DTCS
1. With the scan tool, read all the DTCs.
Is there more than one module with active DTCs "Logged Against" the VSIM?
Yes
- Replace/update the Vehicle System Interface Module. See: Signal Processing Module > Removal and Replacement > Vehicle System Interface Module - Removal.
- Perform the BODY VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Body Verification Test.
No
- Go To 5
5. CLEAR DTC IN MODULE SETTING FAULT
1. With the scan tool, select the module setting the DTC against the VSIM.
2. Clear active DTCs.
Is this DTC still active?
Yes
- Replace/update the module that set this DTC.
- Perform the appropriate verification test for the module being replaced See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests. If there is no verification test for the associated module perform the BODY VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Body Verification Test.
No
- Go To 6
6. CYCLE IGNITION
1. Cycle the ignition from RUN to OFF three times ending with the key in the RUN position.
Does this DTC become active?
Yes
- Go To 7
No
- The condition is not present at this time. Using the wiring diagrams as a guide, check all related splices and connectors for signs of water intrusion, corrosion, pushed out or bent terminals, and correct pin tension.
- Perform the appropriate verification test for the module See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests. If there is no verification test for the associated module perform the BODY VERIFICATION TEST. See: A L L Diagnostic Trouble Codes ( DTC ) > Verification Tests > Body Verification Test.
7. CHECK FOR ADDITIONAL LOST COMMUNICATION FAULTS
1. With the scan tool, read the DTCs.
Does the BCM and other CAN IHS BUS modules show Lost Communication with the remaining CAN IHS BUS modules?
Yes
- Go To 8
No
8. CHECK THE (D265) CAN IHS BUS (125K) (+) CIRCUIT FOR A SHORT TO VOLTAGE
1. Measure the voltage between the (D265) CAN IHS Bus (125K) (+) circuit and ground.
Is the voltage above 5.0 volts?
Yes
- Repair the short to voltage in the (D265) CAN IHS Bus (125K) (+) circuit. The short to voltage is present in one of the CAN IHS Bus (125K) (+) circuits. Use the Star Connectors to isolate portions of the CAN IHS Bus (125K) (+) in order to locate the concern.
No
- Go To 9
9. CHECK THE (D264) CAN IHS BUS (125K) (-) CIRCUIT FOR A SHORT TO GROUND
1. Turn the ignition off.
2. Measure the resistance between ground and the (D264) CAN IHS Bus (125K) (-) circuit.
Is the resistance below 10k Ohms?
Yes
- Repair the short to ground in the (D264) CAN IHS Bus (125K) (-) circuit. The short to ground is present in one of the CAN IHS Bus (125K) (-) circuits. Use the Star Connectors to isolate portions of the CAN IHS Bus (125K) (-) in order to locate the concern.
No
I will watch for your reply.
Mar 3, 2021 at 5:15 PM
MILOS
  • 5 POSTS
I will verify this with my mechanic. thank you Joe. :)
Mar 3, 2021 at 5:25 PM
This can be just a dirty throttle bore or a vacuum leak. vacuum leak or the throttle bore needs to be serviced. here are three guides to go over when fixing the problem:
and
https://www.2carpros.com/articles/stall-at-idle
and
Please run down these guides and report back. Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Mar 3, 2021 at 5:40 PM
MILOS
  • 5 POSTS
Hi Ken, i'm sorry i forgot to mention that my A/C actuator needs to be replaced. Can a bad A/C actuator be a problem here ?
Mar 3, 2021 at 5:46 PM
We need to stick to one problem per thread. Please check out the stalling issue. Please post your new question here, you must be logged in.
Mar 5, 2021 at 8:53 PM
