Car is in limp mode
2007 BMW 320I
7,234 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
CHRIS098
  • 17 POSTS
Car has a misfire. Checked coils and plugs and fuel pump. Code reader said injection changed that problem still there. Been told my chain maybe have slipped. Have not done a compression test yet. Car still starts and drives but no power in limp mode. I am not still driving car atm. But if the chain had slipped would it not damage other stuff? And would car still start etc?
And would a slipped chain cause low compression? In one chamber?
Sep 8, 2018 at 11:15 AM
The car goes into limp mode when the computer has detected a problem. Can I get the codes numbers that would really help? Here is a guide:
Also, if the throttle bore is dirty it will go into limp mode as well this is a common problem with all non throttle cable cars.
If the chain was off you would have low compression in all cylinders. Please run down these guides and report back.
Sep 9, 2018 at 1:36 PM
CHRIS098
  • 17 POSTS
Hi Ken, yeah I did code reader came back as the injection. So I changed that and engine light still on.
I am getting a compression test on the weekend.
If my chain slipped would the crank sensor not throw a code? I am starting to think my chain maybe stretched and it is not closing either intake value or exhaust value which would cause low compression? As it seems the only be on chamber four changed coil and plugs.
Maybe guard rail has broken?
When cars not in gear it revs up fine and seems to have full power just when I drive it it struggle to get up speed.
I am no expert just what I am thinking.
Would a throttle body throw a code?
Thank you for your input Ken.
Sep 10, 2018 at 6:45 AM
The throttle body service may not throw a code. Here is a guide to help you do the compression test:
If the chain slipped it would produce a code. Does the engine make change noises? Can you please shoot a quick video with your phone so we can hear the noise? That would be great. You can upload it here with your response.
The misfire can be causing the issue.
Sep 10, 2018 at 11:01 AM
CHRIS098
  • 17 POSTS
Thanks for reply so soon Ken.
The engine noise sounds like a chat chatting like a lose chain and sometimes when I start it up can hear chain hitting guard rail but not all the time I am not with the car at the moment it is back home.
Yeah, if it had slipped crank sensor would throw a code?
If my chain was loose and cars in limp would would it have damaged anything in my engine is my main concern.
Car still drives and when not in gear revs fine.
The engine noise is not loud at all, but can here a little noise and engine shakes as it is misfiring.
When I go home Friday I will get a video of the engine noise.
Saturday it is going in the garage I do not want to get ripped off so I want to know if a loose chain would damage my engine?
Sep 11, 2018 at 8:59 AM
It is possible the engine is hurt if the timing chain is worn/guides broken. The only way to know for sure is to do a compression test or shoot a video of it running and I can tell from that. Please let me know.
Sep 11, 2018 at 12:27 PM
CHRIS098
  • 17 POSTS
Would a worn chain cause low compression?
Yeah, I will send video Friday and keep you up dated. Thanks for your input.
Sep 11, 2018 at 12:32 PM
Yes, if it has jumped time the compression will be low. Looking forward to the video.
Sep 12, 2018 at 10:05 AM
CHRIS098
  • 17 POSTS
Thanks.
Would it be same if the tensioner as no good?
As I think it maybe just loose?
Or snapped rail would that cause low compression on one cylinder?
Sep 12, 2018 at 9:21 PM
CHRIS098
  • 17 POSTS
I have taken a video ken but not sure how to send it?
Sep 15, 2018 at 4:05 AM
CHRIS098
  • 17 POSTS
Think I have sent it ?
Sep 15, 2018 at 4:57 AM
CHRIS098
  • 17 POSTS
Smoking is a leaking rocker cover gasket. I think was like that before the noise was there.
Sep 15, 2018 at 4:58 AM
Thanks for the video. It sounds like the timing chain guide is broken or you have a vanos that is out either way the front of the engine needs to come apart to see what is going on. Here here the diagrams to help us do the job. I will walk you through the repair. You can get the parts and tools from Ebay. This will not cause low compression on one cylinder though so that is a concern. How low is it? Check out the diagrams (below). Please let us know what you find. We are interested to see what it is.
Sep 16, 2018 at 1:50 PM
CHRIS098
  • 17 POSTS
Hi Ken, thanks for reply. I am not doing work myself as it is a bit too much for me. So it is in garage ATM. I will ask him about the compression tomorrow when he checks the car over.
Sep 16, 2018 at 2:16 PM
CHRIS098
  • 17 POSTS
If a piston was worn or damaged etc., would I hear that?
Sep 16, 2018 at 2:20 PM
Only sometimes. Can you tell if the noise is coming from the front of the engine or the middle?
Sep 16, 2018 at 3:14 PM
CHRIS098
  • 17 POSTS
Front I would say but not 100% sure and that noise just sounds like the chain? The car still drives just in limp mode would it drive if piston was damaged?
I am thinking worst now not good car only has 65,000 on clock as well. :(
Sep 16, 2018 at 3:21 PM
Yep, that is the timing chain. With that many miles it is worth fixing if you can try to get pictures of the broken parts once you get it apart so people can see what goes wrong with them.
Sep 17, 2018 at 11:21 AM
CHRIS098
  • 17 POSTS
But if it is low on compression in one chamber it is another problem not just the chain is it not?
Sep 17, 2018 at 11:27 AM
Correct, how low is it?
Sep 18, 2018 at 9:21 AM
CHRIS098
  • 17 POSTS
Will find out tomorrow Ken and let you know.
Sep 18, 2018 at 5:48 PM
CHRIS098
  • 17 POSTS
Hi Ken,
Update: Car is low on compression.
Chains been checked and seems okay.
Noise is coming from under rocker cover.
What could have gone wrong under there?
Sep 20, 2018 at 9:39 AM
I would remove the valve cover to check the condition of the camshaft you may have a flat camshaft lobe which will cause noise and low compression. Use a flashlight to check each lobe.
Sep 20, 2018 at 3:32 PM
CHRIS098
  • 17 POSTS
Thanks Ken put car off the road atm I have bought a temp car once the BMW goes into the garage. I will update the problem. Thanks for the advice.
Sep 22, 2018 at 9:29 PM
Please let us know. We are interested to see what it is.
Sep 24, 2018 at 10:42 AM
CHRIS098
  • 17 POSTS
Hi Ken, I have a question. I have not had BMW fixed yet. I brought a temp car which last week gear box went bad and now needs new gear nox clutch and duel mass fly wheel I have no luck with cars
My question is about the BMW do you think carbon build up on intake value would cause the low engine power and the misfires and low compression as I am thinking carbon is stopping my intake value from sealing tidy?
Oct 22, 2018 at 7:51 AM
Only if the carbon is so bad it hangs the valves open causing lower compression.
Oct 22, 2018 at 11:20 AM
CHRIS098
  • 17 POSTS
So it is possible. Okay thanks.
Nov 6, 2018 at 2:31 PM
Nov 7, 2018 at 9:38 AM
