Check engine light
2004 DODGE RAM
126,388 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JOANIE0716
The check engine light keeps coming on. My son changed all four sensors and the EGR valve and a code comes up P0405. He also cleaned the carbon out we change the air filter and still comes on. I sometimes drive it for a day with out it coming on. And pop here it comes. Need to get my truck inspected please help.
Feb 11, 2018 at 9:33 AM
The code indicates an EGR issue. Here is a video on how to check it:
https://www.youtube.com/watch?v=DqUCbbKdWf4
I have also attached a picture of one to help you locate it. Note: The code is generic. However, I would recommend confirming it works properly. Also, make sure the wiring to the EGR is in good condition, not damaged, corroded. A poor connection can cause a false reading to the ECM.
One last thought, remove the EGR and make sure there is not a carbon build up.
Feb 11, 2018 at 8:21 PM
JOANIE0716
Hi guys, well my son checked everything. Repaired what needed to be repaired. Last night he took it for a ride and check engine light stay off. I get in it this morning to go to work and it is back on. Please help. Do not know what else to do.
Feb 13, 2018 at 10:19 AM
Did you replace the EGR valve?
Feb 13, 2018 at 10:21 AM
JOANIE0716
How many miles do I have to drive after the check engine light is off? Before I get it inspected?
Feb 13, 2018 at 10:11 PM
Once the codes are cleared you will need to drive it long enough for the monitors to reset which is about 50 miles.
Feb 14, 2018 at 10:15 AM
