Check engine light trouble code P0340
2007 LINCOLN NAVIGATOR
215,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
CARLO.LUNA
Trouble code P0340 came on. Already changed sensor twice. One with aftermarket and the other dealer part. Check engine light still on. Had a mechanic take a look and could not find the problem. Wiring is good. Could it be the crankshaft sensor that needs to be replaced?
Please advice and thank you.
Jul 9, 2018 at 9:30 AM
BMDOUBLE
  • 1,139 POSTS
Another cause of this is a faulty alternator. When diodes go bad it will introduce electrical noise in the system. Have your charging system tested, especially the diodes.
Jul 9, 2018 at 3:22 PM
CARLO.LUNA
Hello BMDOUBLE,
Thank you for the reply. Anything else I can do? Would changing the crankshaft sensor make a difference? My alternator and battery are brand new.
Jul 9, 2018 at 9:39 PM
BMDOUBLE
  • 1,139 POSTS
Did this code pop up after or before the alternator was replaced? And is the alternator a motorcraft brand? Symptoms of a crank sensor is no start or shuts off while driving. Basically if your crank sensor signal is not there the engine will not run.
Jul 10, 2018 at 5:26 AM
CARLO.LUNA
Code popped up a few months later. Alternator is not Motorcraft. Not sure what else to do. Vehicle is up for smog and renewal before months end with no solution. What more can I check? Just a thought, would a loose timing chain tension-er cause this problem? Any other suggestions? Thank you always.
Jul 11, 2018 at 10:51 AM
If the sensor is good and the wiring has been checked it sounds like the PCM is the problem. I have seen where camshaft codes are caused by timing chain issues by not the crankshaft sensor.
Here is the location of the PCM you can try a used one but chances are you will need to have it programmed must shops can do it for $130.00.
Jul 14, 2018 at 12:43 PM
