[quote:48dc5a16c2="hmac300"]it gets to who rebuilt it? If you did yourself and it takes a week to not engage, did you replace all the seals, including the rings? did you pressure check it when it was done to see if a seal didn't roll or get cut? Is it full of fluid? Or what type is it a THM 400 or 350. Afilter could have slipped out of the pickup tube which happens alot and causes them to not engage. Or is there a check ball missing in the valve body or the gasket has/was torn when installed. Regardless the pan has to come off and see if anything falls with it.[/quote:48dc5a16c2]
well let's see....the previous owner rebuilt the transmission and it has about 3000 miles on it so I have no idea about the quality of the rebuild or pressure, I do know he was driving it regular. He says he did a total rebuild FWIW, It is full of oil according to the stick it may be 1 quart over. It is a TCI turbo 350 with a 9" tail shaft about a 1975 model. I did have the pan off and yes the filter was in the bottom of the pan along with the 2 screws and a fair amount of graphite looking material not alot though. I put on a new pan and filter on attached the screws and torqued as required. I did not see any bearings, balls or large stuff in the bottom of the pan. The transmission fluid looks normal with no burnt smell. I did put 8 quarts of new fluid in it when I dropped the pan. It is hooked to a 454 in a 57 Chevy and I believe it may have had a hard life in the car. I hope this additional information helps. All of this has happened after I put the new filter on, but could have been going on before I bought the car. The dip stick was leaking so I put on a Lokar dipstick that has a good seal where it goes into the transmission. I not a retired mechanic but have almost 40 years of mechanical experience. I just don't know automatics like I do 4 speeds. Thanks g.
Apr 9, 2010 at 7:58 PM
