Engine Mechanical problem
1990 Chevy Blazer 6 cyl Four Wheel Drive Automatic
i have 90 s 10 blazer 4 wheel drive been missing and not running well after couple months of replacing almost everything i found vacuum leak i fixed vacuum leak now it runs beautifull untill it getts hot then it blows smoke from leftexhaust it seems like the crankcase is building too much pressure i replaced pvc valve nothing took hose off throttle body no nothing could it be plugged inside throttlebody when i put it in gear under load when its hot i now get a pinging from engine sounds like from underneath at back end of motor but only when under load thx very much for your insight
Sep 13, 2008 at 9:21 PM
