[quote:a6fa3e6a19="penfan"]Engine Cooling problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic 68,000 miles
I have a 1996 Blazer it just started to overheat. On the temp guage when it reaches 210 it doesn't want to go over 40-45 mph. I have changed the egr value, thermostat, and checked the fluid in the radiator. Any help will be greatly appreciated.[/quote:a6fa3e6a19]
Did you check the fan(s)? You have a clutch fan that is run by the belt. Try moving the fan from side to side if there is any play then the fan clutch needs to be replaced. If all it tight spin the fan, Then warm up the vehicle, spin fan again, did it spin the same? if so replace fan clutch.
Now some also have an eletric fan. If it does then start vehicle and turn A/C. Does the fan come on?
Post responses here in forum....
Aug 20, 2019 at 1:26 PM
(Merged)
