1981 Chevy Camaro Bleeding
1981 CHEVROLET CAMARO
81ZAPPER
Brakes problem
1981 Chevy Camaro V8 Two Wheel Drive Automatic
I replaced the shoes on my car, the rr side the cylinder fell apart. I put it back together ( all Seemed to be in good shape). Once the brakes were completed I started to bleed the system because of the cylinder. Now I can not seem remove the air.
After trying with an assistant on the brake peddle for at least 20 pumps of the brakes I still get lots of air. I checked for leaks and eveything seems good
Any ideas?
Also the combination valve has a pin on one side that I read needs to be pushed in before bleeding. My pin is currently flush with the body and will not move in.
In the normal state is this pin to be flush or out somewhat?
zapper
Sep 20, 2008 at 8:09 PM
PEAR69
  • 1,482 POSTS
It can take 50 to 100 pumps to get all the air out. If you are getting air bubbles at the wheel cylinder either keep pumping or get a vaccume pump for your brakes. If you are getting air bubbles in the master cylinder you probably need a new master cylinder..As for the the combo pin open the brake bleeders on the two rear wheel cylinders a little bit and push the pin in.
Sep 21, 2008 at 10:02 AM
