1985 Chevy Caprice check engine light - poor fuel economy
1985 CHEVROLET CAPRICE
235,000 MILES • V8 • 2WD • AUTOMATIC
BILB46
I am restoring a 1985 caprice s.w. with 235000 miles on original 305 engine. It runs great and doesn't burn oil. After replacing the carburator with a remanufactured rochester Q jet and having the transmission rebuilt, I noticed a slight hesitation when accellerating ( minor concern ), the "service engine soon" light coming on when DEcellerating and idling for a couple minutes. Scan codes indicated a rich mixture and since the EGR and O2 sensor were recently replaced, it was determined the mixture control solinoid in the carb was defective. It was replaced along with plugs, dist. cap and rotor, fuel filter and timing adjusted but the "service engine soon" light still comes on the same and my gas mileage is down to 10-12 mpg from 15-17 mpg. My mechanic doesn't know what to try next. Any suggestions?
Apr 1, 2008 at 11:23 AM
Rich mixture possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode
Apr 1, 2008 at 4:23 PM
