2001 Chevy Cavalier abs light and brake light on
2001 CHEVROLET CAVALIER
79,000 MILES • 4 CYL • FWD • AUTOMATIC
RODDER44
the ABS light on and brake light on too car been setting with a bad motor for about 6 month and i put a motor in it and now the lights are on and when driveing the rear brake lock up no front brake check all fues and wireing senor for abs on all wheels
Jan 22, 2010 at 8:53 PM
CHRIS1982
When both lights are on it usually means, that you have a leak in your brake system somewhere. Check for leaks at the master cylinder, along your brake lines and calipers. If your Cavalier has brake drums then check underneath your brake drum as well.
Feb 12, 2010 at 8:04 PM
