heater core replacement
2001 CHEVROLET CAVALIER
BIGPETE69
Heater problem 4 cyl Front Wheel Drive Automatic 109000 miles
how tough of a job is it to replace the heater core in the above referenced car. I am a pretty good mechanic, but I don't like surprises! Instructions if possible? Thanks!!!!
Jul 12, 2008 at 8:21 PM
You will need to drain the coolant first and disconnect the battery. Also you will need to vacuum down and then recharge the ac system when you are done. Here is a guide for that.
Here is a guide that will give you an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/replace-heater-core
Here are some diagrams (below) of your car to help you get the job done
Jun 12, 2017 at 3:47 PM
SHANNON HART
Heater problem
2001 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 164252 miles
i am wondering how you install a heater core on my 2001 chevy cavalier i think it went out and where is the heater core located??
Jun 12, 2017 at 3:48 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1799.jpg
DCMACK
Trouble removing heater core from housing box in a 01 chevy cavalier
Take a look at the attached pic and let me know if it helps. It shows the entire unit in an exploded view. Hopefully, you can see something that needs removed.
ROCKGIRL_06
Smells problem
1998 Chevy Cavalier 4 cyl Automatic
my car leaks coolant when parked. i smell a sweet smell inside my car and a film covers the inside of my windshield. i have replace thermastat and water pump. have check head gasket it is good.
Jun 12, 2017 at 3:49 PM (Merged)
Sounds like the heater core is leaking-you smelling the sweet odor
GILLY3
Engine Cooling problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 110000 miles
do you have some step by step to remove heater core.chiltons is not much help.ther is a plastic piece going from the floor to the bottom of heat box unsure how to get it out
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL: Disable the SIR system. Disconnect the negative battery cable. Properly drain the cooling system. Raise and safely support the vehicle. Detach the heater hoses from the heater core. Carefully lower the vehicle. Remove the instrument panel as instructed below: REMOVAL OF INSTRUMENT PANEL: Remove the instrument panel cluster trim plate. Unfasten the screws from the top of the cluster, then pull the cluster rearward to remove. INSTRUMENT CLUSTER MOUNTING
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528003cf21_2.jpg
HEATER CORE AND RELATED COMPONENTS
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528003cf21_1.jpg
INSTALLATION: Position the heater core, then secure with the mounting clamps. Attach the heater core cover. Install the DERM with the attaching bracket. Install the instrument panel. Raise and safely support the vehicle. Connect the heater hoses to the core. Carefully lower the vehicle. Properly refill the engine cooling system and check for leaks. Enable the SIR system. Connect the negative battery cable, then start the engine and check for proper system operation and/or leaks.
LRICHARDSON
having problems removing dash
Here are the directions. Also, I have attached an exploded view of the system. I hope it helps.
Remove the instrument panel. For details, please refer to the procedure located in Body & Trim of this guide.
Remove the DERM with the attaching bracket.
Detach the heater core cover.
Unfasten the heater core mounting clamps, then remove the heater core.
To install:
This is the only exploded view picture I could find of the system. I hope it helps. It shows the entire system.
SISSYLOU
I have to change the heater core on my car. Where is it located and what will I have to do to change it?
DOCFIXIT
  • 18,828 POSTS
First need to remove instrument panel to be able to remove HVAC unit BIG job can download Mitchell from this site for instructions
PITZFAM
Heater problem
1999 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
How to change a heater core in my 1999 chevy cavalier.
MMPRINCE4000
  • 8,548 POSTS
Use the car repair manual link in this thread, or get a Haynes manual.
Generally you will have to remove a portion of the interior dash to get the the heater core, after draining coolant, remove old core and replace it with new core, tighten down coolant hoses.
CLAUDIA0924
how to locate the heater core on a 2000 chevy cavalier? Its a 2.2.And what to diconnet? to but a new one back.
Sep 9, 2017 at 7:46 PM (Merged)
HEATER CORE REPLACEMENT
REMOVAL PROCEDURE
Remove the HVAC module. See: Housing Assembly HVAC\Service and Repair
Turn the HVAC module over.
Remove the heater core case cover screws and cover.
Remove the heater core bracket screws and brackets.
Remove the heater core.
