I have an oil pressure problem at idle.I thought it may have been sludged up.Pulled the oil pan and it was clean.However there was a rubber or neoprene "skirt" that goes around the oil filter casing inside the oil pan.It no longer fits as it should will the system work right without it?I am thinking it gets really soft when the oil gets to operating temperature and is getting sucked up against the pick up screen for the oil pump as I have already replaced the oil pressure sending unit and this did not help.
Mar 1, 2009 at 3:48 PM
