1992 Chevy Corsica water pump
1992 CHEVROLET CORSICA
SPORTYMAN_69
Engine Cooling problem
1992 Chevy Corsica 6 cyl Front Wheel Drive Automatic
I need a diagram of where the water pump is and how to replace it.
Jan 31, 2010 at 8:53 AM
ROYGAM
  • 4 POSTS
it in the right hand side of the motor if you seat in the car.
you need to take of the acssories belt out,then you need to take of 4 screws from the water pump wheel/
after you take it off you`ll see 5 screws
that you need to take off as well/
take the new water pump,put a new gasket bolt in the 5 screws,then put in the round plate put the 4 bolts than put the belt ,start the car fill water inside the system,take off the air from the system,check for no licks and youre set.
good luck
Jan 31, 2010 at 5:53 PM
