How do I replace my serpentine belt. The pulley on top has a motor mount does it have to be removed and if so does the motor need to be supported??
Nov 29, 2008 at 8:06 PM
BMRFIXIT
CERTIFIED EXPERT
Locate the tensioner and lift away from the belt
Be sure to draw how the belt is routed if there is no under hood sticker showing it
Read the guide below, its not vehicle specific, but it will help
https://www.2carpros.com/articles/replace-serpentine-belt
Nov 29, 2008 at 8:12 PM
JCAPONE
MEMBER
1 POST
My serpentine belt keeps breaking, I found that the bottom pulley (with grooves) does not move. Is that the problem?
Nov 19, 2018 at 5:36 PM
(Merged)
KHLOW2008
CERTIFIED EXPERT
Hi jcapone,
If the main pulley is not moving, the serpentine belt would not move. The main pulley must move when the engine is running.
I am confused by your question.
(Merged)
LISABARNETT
MEMBER
1 POST
Engine Mechanical problem
1994 Chevy Corsica 4 cyl Front Wheel Drive Automatic
need to know the way to put it on
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
Let me know if your engine size is different than 2.2L
2.2L Engines:
Thanks for using 2CarPros.com!
(Merged)
SAMPO2345
MEMBER
1 POST
What is the length of the belt without ac compressed bearing fried so don't need ac was gonna put belt on and need to know length without ac
(Merged)
LITTLEONE42069
MEMBER
1 POST
1994 Chevy Corsica 6 cyl Wheel Drive Type unknown Automatic 30000 miles
I need a printout that shows how to replace the belt on the engine
(Merged)
BMRFIXIT
CERTIFIED EXPERT
check the diagram below
locate the tensioner and pull away from the belt
pull belt
(Merged)
HALLSHIVE91
MEMBER
1 POST
I need a diagram for a v6 3100 serpentine drive belt
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
(Merged)
2CP-ARCHIVES
MEMBER
How change serpentine belt on 2.2L 1996 corsica with 184,000 miles
(Merged)
CERTIFIED EXPERT
Here is a guide that will show you what you are in for when doing the job.
(Merged)
LJFREELAND
MEMBER
1 POST
I started the car this morning and heard a strange clicking kind of noise. Thought a bird got caught in the belt or something. Then realized I had no power steering. Looked under the hood and the belt is so way loose, but not broken. How do I tell if its the belt or the tensioner. The belt is real loose. It's old but not frayed. Some cracks in it. Could it have stretched that far? How can I tell if it's a bad tensioner?
(Merged)
WRENCHTECH
CERTIFIED EXPERT
If it's the correct belt, routed correctly and none of the pulleys are bad, then all it can be would be the tensioner.
(Merged)
KOLEC94
MEMBER
my drive belt is going bad, and i have been putting oil on it and it slipped off and now i cannot figure out how to release the tensioner on the belt.
(Merged)
HMAC300
CERTIFIED EXPERT
worse thing you can do is to put oil on a belt. clean all the pulleys with choke cleaner or brake clean then replace the belt and tensioner. see picture arrow shows which way to move tensioner.
Image (Click to enlarge)
(Merged)
KOLEC94
MEMBER
how do i move the tensioner?
(Merged)
HMAC300
CERTIFIED EXPERT
i already showed the direction in first reply with the picture move it in the way of the red arrow.
(Merged)
KOLEC94
MEMBER
ok so i have to unbolt the tensioner?
(Merged)
HMAC300
CERTIFIED EXPERT
only if you replace it which you should due to age and replacing belt as well.
(Merged)
NOODLES74
MEMBER
1 POST
Engine Cooling problem
1995 Chevy Corsica 4 cyl Front Wheel Drive Automatic
need a diagram on how to route a serpentine belt
(Merged)
BIGJIM79
MEMBER
look on google image and there about 400 pics of belt route
(Merged)
BIGJIM79
MEMBER
heres aphoto
(Merged)
65MPH
MEMBER
How do you replace the serpentine belt that turns all the accessaries ? What do I need to do?
